dodge_mich
2/25/2008 6:55:03 PM
Did the 1994 Discovery have keyless entry? I have a spare fob fob, but the programming procedure does not work for it. I know it does have the alarm, so it seems like it should have keyless as well, but I may be mistaken.
dodge_mich
2/25/2008 8:26:46 PM
At this point, I'm thinking it's only on '96 and up.
I can't even get to the point where I use the remote, following the manual procedure:
1. Starting conditions: ignition off, doors unlocked,
bonnet switch depressed.
2. Carry out instructions 3. to 9. within 8 seconds.
3. Switch ignition ON.
4. Switch ignition OFF.
5. Lock doors.
6. Unlock doors.
7. Release bonnet switch.
8. Switch ignition ON.
9. Switch ignition OFF.
If alarm is correctly accessed, horn will sound and
LED will light. It is now possible to programme two
handsets of correct frequency to vehicle alarm ECU.
This must be carried out within two minutes.
10. Press and hold down button on first handset until
dash LED flashes.
11. Repeat instruction 10. for second handset.
12. The LED will extinguish if both handsets have
been initialised correctly.
RamblingMan
2/25/2008 11:41:25 PM
My '94 was keyless entry.
