Cruise Control Fix
Old 11-08-2009, 05:39 PM
cranky's Avatar
Default Cruise Control Fix
I've been trouble shooting my Cruise control and using the steps below I've been able to isolate the problem.
This has been a very handy and easy to follow guide.
My Disco is a '94 and the proceedure seems to work okay.
Land Rover Cruise Control Problems
CREDITS: Charles Allen (super-poser)
I had some problems with my Cruise Control(CC) which a few of you seem to have and found some good things on the internet. The only problem was, none of it worked in my case, every time I checked something turn, has access to some software that had the picture you see below and the troubleshooting guide that follows. Keep in mind, this requires a fair amount of electrical system familiarity and tools. For me, it rated fairly high on the DIY difficulty.
At any rate, you will want to check all vacuum possibilities before you continue with this guide. The vacuum from the pump under the jack at the front of the engine compartment on the driver's side, to the T junction just before the firewall, from the T junction to the actuator bulb, and from the T junction through the firewall to the
brake cut-off switch.
One other disclaimer here: My disco is a 98, I know for sure that the 96's are different, but am not sure when the change took place. Okay, you will need access to the Cruise Control ECU connector which is located
behind the glove box. Remove the glove box and you will see this (cruise pic):
Now, with a few tools for testing electrical circuits and some patience lets begin:
1. Turn ignition on. Turn CC system on. Put transfer case in HI range and gearshift in forward gear. (from this point forward I will say "in drive" to mean the previous sentence). Ensure clutch pedal is released. Disconnect cruise control ECU connector. Connect negative lead of voltmeter to CC ECU harness connector terminal no. 8 (black wire) and positive lead to terminal no. 10 (orange/white wire). If battery voltage exists, go to step 3. If battery voltage does not exist, go to next step.
2. Turn ignition off. Using ohmmeter, check resistance between ECU harness connector term. no. 8 (black wire) and ground. If resistance is less than one ohm, go to next step. if resistance is not less that one ohm, repair black wire between CC ECU and ground.
3. Ensure ignition and CC system are on. Disconnect CC ECU connector. Using voltmeter, check voltage between CC ECU harness connector term. no. 4 (red/yellow wire) and ground. With RESUME/DECEL switch pressed, battery voltage should exist. With RESUME/DECEL switch released, no voltage should exist. If voltage is as specified, go to next step. If voltage is not as specified check circuit from steering wheel switch to CC ECU.
4. Ensure ignition and CC system are on. Ensure CC ECU connector is disconnected. Using voltmeter, check voltage between CC ECU harness term. no. 3 (gray/yellow wire) and ground. With SET/ACCEL switch pressed, batter voltage should exist. With SET/ACCEL switch released, no voltage should exist. If voltage is as specified, go to next step. If voltage is not as specified, check circuit from steering wheel switch to
CC ECU.
5. Ensure ignition is on. Ensure CC ECU connector is disconnected. Using voltmeter, check voltage between CC ECU harness term no. 5 (green/purple wire) and ground. With brake pedal pressed, battery voltage should exist. With brake pedal released, no voltage should exist. If voltage is as specified, go to next step. If voltage is not as specified, check green/purple wire between CC ECU and stoplight switch. Check stoplight switch. Repair as necessary.
6. Turn ignition on. Reconnect CC ECU connector. Using voltmeter, back-probe between CC ECU harness term no. 11 (yellow wire) and ground. Spin a rear tire at about 3 MPH. Voltage should be about 2.5 volts, or vary between zero and 5 volts. If voltage is as specified, go to next step. If voltage is not as specified, check yellow
wire from CC ECU to the vehicle speed sensor. Check ECU. Repair as necessary.
7. Turn ignition on. Turn CC system on. Disconnect CC ECU harness connector. Connect a fused jumper wire between CC ECU harness term No. 1 (Orange/blue wire) and battery voltage. Connect another fused jumper wire between CC ECU harness term no. 7 (orange/red wire) and ground. If vacuum pump operates, go to
next step. If vacuum pump does not operate, check orange/blue and orange/red wires between CC ECU and vacuum pump. Check Vacuum pump. Repair as necessary.
8. Ensure ignition and CC system are on. Ensure CC ECU connector is disconnected. Connect a fuse jumper wire between CC ECU harness term. no. 1 (orange/blue wire) and battery voltage. Connect another fused jumper wire between CC ECU harness term. no. 7 (orange/red wire) and ground. Connect another fused jumper wire between CC ECU harness term. no. 6 (orange/pink wire) and ground. Vacuum pump should operate, valve should close and throttle should open wide. If system operates as specified, repair CC ECU. If system does not operate as specified, check orange/pink wire between CC ECU and vacuum pump. Check vacuum pump. Repair as necessary.
I hope this helps someone. It's a fairly easy way to diagnose any electrical or component problem with this cruise control system. Read: Do steps 7 and 8 to check your vacuum pump.
In my case the ECU was bad.
HTH, Good luck
Kit
P.S. This procedure is copyright 2001 MRIC and Snap-on Tools Company.
________
Live Sex Webshows
Old 11-08-2009, 05:43 PM
cranky's Avatar
I might add that the pump worked backwards in steps 7 & 8. It blew instead of sucked!
I'm guessing the ECU is broken.
________
VAPORIZER I
Old 09-05-2010, 01:13 AM
nat1971a's Avatar
Hey just wanted to post a few photos as i just fixed my cruise control on a 98 disco. First i took a gamble and replaced the cruise ecu without doing any diagnosis. Cost only 60$. This didnt fix it
The real fix was the hoses cracked at the T Piece behind the window washer. See photos attached. All I did was shorten the vaccum lines. Tested ok today
One of the photos attached show the cruise ecu behind the glove box. And the other photo shows the now fixed vacuum lines at the t piece behind the window washer.
Anyway that is what fixed my cruise control.
Attached Thumbnails Cruise Control Fix-cruiseecu2.jpg   Cruise Control Fix-vacuumlines.jpg
Old 09-05-2010, 01:09 PM
tweakrover's Avatar
did the cruise control light in your gauges work? my deal is if the lights work it would be a vac problem but if it didn't it would be electrical( ECU, speed sensor, pump, or wiring).
Old 09-06-2010, 03:32 PM
nat1971a's Avatar
Yes my cruise button lit up. So check your vacuum lines. I didnt know what i was looking for so i just had a good look around until i found this hose with the tpiece in it which was all cracked and about to fall apart. All i had to do was use a knife to shorten the hose. cost nothing to fix it. think it took about 5 minutes to fix it in the end
Old 07-13-2011, 10:48 AM
Disco Luke's Avatar
I have a 2004 Disco and my cruise control won't work. It's not the vacum hose and my cruise control light comes on when I press the button. What should I look for to get it working?
Old 11-19-2011, 09:30 PM
fratera01's Avatar
I am having problems with my crusie control. Sometimes it works and sometimes it does not. If I get it to engage it will cut off on me randomly. I checked my ecu using the above test and in step 5 without touching the brake there was voltage. Where is the stop light switch and how do I know for sure if this is the problem?
Old 11-20-2011, 09:17 AM
On a disco One and a disco two are the vacuum lines check them first for any perforations. Then get a vacuum pump and check to make sure the system is holding and producing vacuum. That means on a disco one make sure the brake pedal and the clutch pedal hold vacuum. no vacuum no cruise. Also make sure the pump is running and producing vacuum. its not engine vacuum so don't expect 16 HG, expect along the lines of 5 HG. DO NOT USE ENGINE VACUUM ON THE SYSTEM OR ELSE THE ENGINE WILL RACE TO IT BLOWS UP.
Old 07-11-2012, 10:39 AM
TMadsen's Avatar
Default Wheel sensor voltage
Please help me up you can . My cruise does not work at all . I have replaced all hoses and gone through all checks . All diagnostic checks are good except the wheel sensor voltage . When checking to the voltage I get a constant 8.75 volts . Sometimes when all wheels are not turning I get 12 volts sometimes when wheels are not turning I get 0 volts . When I turn a rear wheel by hand the voltage will vary between about 5 and 12 volts . When I turn the wheel with the engine I get a pretty steady 8.75 volt no matter how fast or slow the wheel is turning . I get the exact same results when turning either rear wheel . I true testing with front wheels and get 0 volts at all times . Is this normal ? I have tried 2 different ecu's . Antilock brakes seem to work fine . No fault lights are on . Speedometer works ok , it does fluctuate a little now and then and it does read about 3mph slower then actual speed .
Old 10-30-2012, 01:11 AM
DROVER1984's Avatar
Cool Cruise help....
I have a 01 Disco 2 and the cruise does no work on it. Dash lights up, and if you push and hold the cruise button, it will attempt to hold the speed, but slowly declines in speed...what vacuum hoses am I looking for on a 01?
Quick Reply: Cruise Control Fix
