Sponsored by: CARiD
Alarm intermittently honks car horn
Old Aug 30, 2010 | 11:23 AM
wcwhiz's Avatar
Default Alarm intermittently honks car horn
I have been told that the alarm module in the 2004 models is built into the body position module. Any idea how hard to change. Im unsure exactly where it is located. ??
And does it have to be reprorammed to the car or is it just plug and play??
Any help appreciated
Old Aug 30, 2010 | 11:29 AM
hilltoppersx's Avatar
should honk if a door is ajar. that is the obvious question...
Old Aug 30, 2010 | 02:15 PM
Give us more information, when does it honk, is the truck locked, is it super locked and are any windows/ sun roof open?
Old Aug 31, 2010 | 06:15 AM
dont forget the hood. If the hood is shut properly and in a stiff breeze it will go off.
and if it does go off it might be the switches.
Old Sep 1, 2010 | 07:32 AM
wcwhiz's Avatar
Smile alarm problem
I believe it is one of the door sensors the only problem is to diagnose which one it is?? Nearest land rover dealer is 60 miles away.
Old Sep 1, 2010 | 08:05 AM
Last place you should go is the dealer, they will try and sell you some new doors to fix a switch problem. Try and find a local shop that has some Rover experience.
Old Sep 1, 2010 | 08:55 AM
where are you located?
Old Sep 1, 2010 | 10:48 AM
yloDiscoII's Avatar
I find I have an issue with the back gate. Over time it has sagged on the hinges just enough where I have to slam it to shut it properly, so as not to get the "honk"
Old Sep 1, 2010 | 11:12 AM
If you are having a tail gate alignment issue, go get it fixed before it gets worse and really costs you some big $'s.
Old Sep 1, 2010 | 12:54 PM
yloDiscoII's Avatar
Thanks for the heads-up Mike. It's been one of those nagging problems I keep neglecting to look in to.
Is there an easy fix? New bushings on the hinges? right now it is pretty difficult to open and close without exerting quite a bit of force. My wife has a helluva time even getting it to swing out all of the way.
(sorry to hijack your thread a little bit whiz)
caymandrew
Jun 8, 2015 10:16 PM
lipadj46
Aug 13, 2009 07:47 PM
PDXDisco
Jun 25, 2008 05:21 PM
willstevens
Dec 11, 2007 11:41 PM
igriego
Jun 6, 2005 04:54 PM
