Sponsored by: CARiD
97 disco, need help......
Old Sep 4, 2010 | 03:36 PM
gray1's Avatar
4th Gear
Default 97 disco, need help......
Hello and thanks in advance for anyone who can help me.
I recently got a 1997 discovery se7 and i have been fixing a few things on it, and ran into a problem i cant figure out.
I ordered a steering damper because the old on was severly smashed, I took the disco in today to get the tires balanced and the mechanic noticiced that the bar that the steering stabelizer shock hooks into is bent badly.
I looked everywhere for the rod and have no idea what it is called and where i can get one.
The tie rods at the end are newer, I just need the bar that the steering damper mounts to from tie rod end to end.
any ideas of where i can get this?what the proper name is for the part.
thank you all for helping.
Old Sep 4, 2010 | 06:10 PM
Before you go spend the money, pull it off and put it in a vice, you should be able to straighten it with out replacing it, I had to do that one.
Old Sep 4, 2010 | 08:25 PM
antichrist's Avatar
Behind the axle track rod, in front, drag link or steering rod.
I'd replace it, once bent it's weakened and will be more likely to bend in the future.
I have bent them back when off-roading in order to get home.
Old Sep 4, 2010 | 09:27 PM
gray1's Avatar
4th Gear
It is the Bar that the stearing stabalizer is on, thats what i need the name of.
I will try to bend it back, but i would prefer to get a new one, but without the proper name its hard to order or explain.
I have went to 3 autp stores and they say it is not made, or sold any longer.
Old Sep 4, 2010 | 10:39 PM
Danny Lee 97 Disco's Avatar
I bought a used drag link from Will, at RoverGuy.com. Go to the site to get his phone mumber and give him a call. He said he had a pile of them in his shop.
Old Sep 4, 2010 | 11:00 PM
gray1's Avatar
4th Gear
so the steering damper mounts on the drag link?
whatever the piece is called that the steering stabilizer(damper mounts to, thats what i need the name of.
Old Sep 4, 2010 | 11:18 PM
gray1's Avatar
4th Gear
from reasearch i have been doing tonight it looks like it may be called the Track rod or the Long rod.
Now just have to find one quick.
ScreamingLife
Apr 25, 2013 08:32 PM
striversrowatl
May 1, 2010 11:20 AM
Speed racer
Oct 11, 2008 10:56 PM
