Sponsored by: CARiD
Multi problems, need help!
Old Sep 5, 2010 | 09:02 AM
garthak's Avatar
Default Multi problems, need help!
Ok, Soory I didn't post in nubi area first....
have multi issues..
Have:
96 Disco I 3.9L V8
Issues:
run's fine for 20-30 min... idle or at speed...
then engine starts too hesitate/ surge/ cut out...
engine occasionally idles high (1500rpm)
Replaced:
TPS (was faulty to begin with)
Plugs
Wires
Cap
Wires
End:
Still cuts out when driving or idling
Help? Ideas?
Old Sep 5, 2010 | 07:14 PM
Sounds like a bad VSS (vehicle sped sensor), it is the trucks speed limiter, its cuts spark to the cylinders to slow you down.
When it goes bad it will cut spark at random.
Old Sep 5, 2010 | 08:10 PM
garthak's Avatar
is there a bypass for that?
Old Sep 5, 2010 | 08:59 PM
A by pass for the VSS? No.
You need to replace it.
denis06
Mar 3, 2008 03:09 PM
dow
Aug 23, 2007 11:07 PM
